Autoglym Super Resin Polish (SRP) F.A.Q
srp
1 reading
543K views 237 replies 158 participants last post by  A.B
#1 · (Edited)
Hi guys,
Since there is always atleast 1 Autoglym SRP question per page in this section, I decided to collect most questions and answers about it and put them in to one thread. Maybe this thread could be stickied, anyways I hope it can help alot of people out.
I've been a happy SRP user for a couple of years now. I know what to expect from it, I know what it's capabilities are, so I won't be dissapointed real quick.
Good luck!
Questions
What is Autoglym Super Resin Polish (SRP)?
SRP is probably one of the most popular products from Autoglym.
It is a lightly abbrasive polish with a lot of fillers and it also contains a light sealant.
What will the fillers do?
Fillers fill up swirls and light scratches for a certain amount of time. Since there is also a light sealant in SRP it means that it offers protection for maybe 1 or 2 months. The fillers will disolve after some time so each time you wash your car, more swirls will be visible. To keep that nice looking paint after when you just polished your car with SRP, you have to polish with SRP about 6 times a year.
How much correction does SRP offer?
The cuttingfactor from SRP between 0 to 10 would be 0,5 or 1. It isn't meant to offer real correction, although it gives a corrected look to your car when applied correctly.
How can you apply SRP?
SRP can be applied by hand, dual action polisher, random orbital polisher or rotary polisher.
How do you apply SRP by hand
You can apply SRP by hand using foam pads like Meguiar's Gold Class High Tech Applicator Pad, German Applicator, or any other foam applicator. Microfibre pads work too.
Apply a few Skittle sized blobs on your applicator and spread it on the paint. Work on areas which have the size of about half a door. Then work it really well untill it becomes a little hazy or clear. Then buff off with a microfibre towel.
How do you apply SRP by machine?
Use a light polishing or polishing pad. Apply a few Skittle sized blobs on your applicator and spread it on the paint. Work on areas which have the size of about half a door. Then work it really well untill it becomes a little hazy or clear. Then buff off with a microfibre towel.
Can you apply more layers of SRP
Yes you can. The more layers you give your car, the more swirls that will be filled. Up to 5 layers would work really good.
Does SRP needs to cure?
It's not necessary, but you can let it cure.
Can you use a glaze after SRP?
Yes, you can use a glaze after SRP.
Can you top SRP with a sealant and/or wax?
Yes, one of both or both works great. A really good sealant to top SRP with is Autoglym Extra Gloss Protection. A good wax after SRP is Autoglym High Definition Wax but any other wax will work fine, as long it won't contain cleaners since cleaners remove the fillers.
Can SRP leave scratches or marring?
No, but dirty applicators or too aggresive pads with the machine can.
How do you remove old SRP from the paint?
By polishing or claying the paint.
Can you use SRP on vinyl stickers?
Yes, you can. Don't apply it to harsh, but other than that it won't do damage.
Will SRP do a good job on faded colors?
SRP will do a great job on faded colors!
Can SRP be used on wheels?
SRP leaves a great finish on wheels, along to some protection against brake dust and road grime!
How to prevent dust with SRP?
Lightly spritz your pad with water or detailerspray. This will give the SRP a thinner coverage with less dust.
Also working the polish in for a few minutes until it's gone clear will result in very minimal residue to remove, and what there is won't come off 'dusty'.
If there are any more questions, feel free to leave them and I will add them to the list!
Thanks for looking,
Matthijs
#165 ·
I normally either run it round the whole car 1 panel at a time until im back at the beginning but its just as happy to be layered almost as soon as its been buffed off.
Hello,
I read all thread and have one question abuot AG SRP and EGP: can i work with this products in direct sunlight? Or surface of mashine must be cool? Thank all for answering to these questions...
Yeah, its fine. bit harder to work but minimal.
#170 ·
I bought a bottle of SRP yesterday and straight away gave it a go with my Meguairs G220 DA polisher with a Meguiars Finishing Pad.
I used setting 4 (6 is maximum) with medium pressure and applied four blobs. Firstly I will say that it is very runny so went everywhere. Secondly I found that I had to keep adding more polish.
My questions are:
1) Do I need to prime the polishing pad?
2) Per half a door I am using about 4 small blobs, is this enough?
3) I worked the panel by making about four passes until the polish became clear and then I left it to haze before buffing, is this correct?
4) Can I spritz the pad or panel with water when working the polish to extend the polishing time?
Thank you in advance.
#171 ·
My questions are:
1) You need to prime the polishing pad with every polish! It helps the pores to absorb the product.
2) Its definitely enough. Use any more and you may get dusting
3) Yes thats fine.
4) Yes you can spritz with water to make it last longer.
#172 ·
Thank you that is good info. How thick/runny should SRP be? Mine is quite runny, it pours out of the bottle rather than needing to squeeze the bottle. It almost seems too runny. I have given it a good shake but it is no better. It is their new formulation so I am not sure if that will change anything. I only ask because videos online show it to be a thicker consistency than my bottle.
#176 ·
My understanding is that being a polish means it is meant to improve the look of the paint. It does also have some resistance to water but adding a wax or sealant is supposed to improve the life of the fillers that hide scratches.
I use autoglym extra gloss protection and it seems good. Easy on and off and water sheets off quickly. Not sure how long it will last though.
#178 ·
Yep, the AG SRP will add the shine. Dont expect it it to last too long if its left without anything on top. I personally use FK1000p or Megs #16 which works very well and are both very durable.
The new formulation has more micro abrasives and more fillers so gives a better finish than the one it replaced like 2 years ago. It also has very little in terms of dusting compared to the earlier version.
Remember, no matter what wax you use, it'll look the same so you may as well just get the cheapest, quality one you can. Thats where the Meguiars #16 comes in but im sure collinite 476s would also do a good job too.
#182 ·
Firstly, can I just say what an excellent Q&A article this is.
As someone who has just purchased a brand new BMW, I went out and bought a few AG products.
Amongst my purchases were the AG SRP and the AG Extra Gloss Protection (EGP).
I am just a bit confused as to the purpose of the AG SRP, as I was advised that for a brand new car this product should only be used for minor scratches that may appear (a bit like T-cut) , rather than as an actual old fashioned “polish”.
Instead, after washing the car and drying it, I should be using the AG Extra Gloss Protection only.
So I am just a bit concerned as to how I should go about using these products on a brand new car, which obviously has no scratches as yet. (Not sure if it makes any difference, but the car is ‘jet black’).
The AG website states :
1) Wash car
2) Apply SRP
3) Apply EGP
I would be grateful for any thoughts on this, before I start to use any of these products and make a total mess of my new car !!! .
Thanks in advance.
#183 ·
I am just a bit confused as to the purpose of the AG SRP, as I was advised that for a brand new car this product should only be used for minor scratches that may appear (a bit like T-cut) , rather than as an actual old fashioned "polish".
So I am just a bit concerned as to how I should go about using these products on a brand new car, which obviously has no scratches as yet. (Not sure if it makes any difference, but the car is 'jet black').
1) Wash car
2) Apply SRP
3) Apply EGP
Thanks in advance.
the srp isnt like t cut , think of it as a gentle clean and polish before the egp , even new cars may have been stood outside sometime and will benefit from a gentle clean to make sure you have a good base for egp
#184 ·
SRP isn't really like T-Cut; it is a very, very mildly abrasive polish with virtually no cut that also has chemical paint cleaners to enhance shine and silicon fillers to fill-in and mask any light scratches or imperfections.
If the paint seems perfect , then you can certainly just use the EGP, but the SRP wont do any harm at all to your new paint and will likely give further shine and clarity to the paint, even though it is new paint, as new cars still pick up dirt and surface contamination during transport and storage.
It certainly doesn't cut into the paint like T-cut does.
#186 ·
People are mentioning that you should (or could) use a wax after EGP, can any wax be used or will some take off the EGP? I was thinking to use Collinite 845. Also what will adding the wax on top of EGP achieve? I presume longevity and gloss.
Secondly, how long should EGP be left on for (to cure) and does it matter if it gets damp while curing (i.e overnight)?
Thirdly, if I use Meguiars Ultimate Compound, should I use IPA before applying SRP or can I go straight ahead with SRP?
