Which cleaner wax is the best?
I agree with you in every aspect; however for me I like to use DA to discover the true effects and the crosslink between products such as DJ LPL, DJ SNMP, ect and finishing pad (no cut) on soft paints. I'm also trying to come across with the best technique and approach for controlling the DA and speed to give the most depth and glossy finish as possible with the setup in mind for avoiding paint thickness reduction. Of course you can argue me why I'm doing that but again it's just me to discover and develop new things. BTW I'm only work at this project sometimes during weekend and it's time depending.Pardon my astonishment! Why on earth would you want to do this with a
machine? Assuming you started with perfectly clarified paint, and in the
interim you've been pretty careful with your washing technique, you come to
a point, say after 6 months where you want to strip back to clearcoat.
Words fail me... to what end? I hope that what follows doesn't sound like I'mI agree with you in every aspect; however for me I like to use DA to discover the true effects and the crosslink between products such as DJ LPL, DJ SNMP, ect and finishing pad (no cut) on soft paints.
Which is basically my point. Dave, the OP has soft paint and asked about...but the likes of lime prime and tripple have certainly performed better via DA, although on well kept paint the benefit is less.
Oh crumbs, that makes detailing sound like a chore, rather than a pleasure.Results from a pre-wax cleaner by DA > hand. You can get a nice finishing polish effect if you step up the pad, which is quite often enough to remove all wash swirls. More than safe enough to use every 3 months for the rest of the cars life!![]()
Many thanks for your good wishes. There isn't any need to apologise, threadsFirst I would like to apologize to all of you if this thread has been moved away from the original title. Pleas all accept my apology.
Second, Steve, I sent you PM.
Happy new year to all
