1 - 9 of 9 Posts
I have searched and found a few results, not had the pleasure of working on a car with a lot of chrome trim before and wondering what is best these days to protect it...
Thanks in advance for any replies
Rob
Discussion Starter · #6 ·
Just out of curiosity, will most of these fancy coating products stick to and protect chrome?
That's what I was wondering with the likes of gtechniq which I still have some of.....
I put it on some exhaust tips around 4-5 months ago and seeing the car for first time since then this weekend so will see how easy it is to clean up.
I personally have not coated many chrome parts with this coating but I am sure it will last longer and offer more protection than a wax based product.
I still have lots of v3 left so will try to find some chrome wheels to play with see how it does.
  • Like
Reactions: lowejackson
Hi there, Yes it will stick to chrome or any other bare metal surface.
A single layer stops bare aluminium from oxidising, apply it on steel - single layer stops it from rusting. Apply a few layers and you will build up heat resistance up to +1200c, so UNC v3 can be used on pretty much any bare metal surface.
If you use a wax based product on exhaust tips, for example, it will melt off in the first few miles because of the heat and exhaust gasses.
See this video for reference - GTR exhausts are probably one of the worse to look after because of the heat and smoke they blow out, with UNC v3 covering them, it's a breeze to clean!
Thanks,
Janis
1 - 9 of 9 Posts
