The greens wear quite quickly, but the yellow & blue seem to last forever.what are the 3M pads like for wear?
You're right, the Dodo Juice FIN pads were designed for use with a Rotary, with the whole 'Deep Grove' idea to keep the pad cooler than say a Waffle Pad and reduce sling.The fins on the dodo pads are to help keep the pad as cool as possible, I was under the impression that the fin pads are for rotary polishing but would work with a da if needed.
Gonz.
Which lake country for finishing? Ever tried their Gold Jewelling?Out the mix I have I find reaching for the lake county both da/rotary, mostly used the cg hex this year but finishing has always been lake county.
Both constant pressure and hydro tech, the finishing pad's I use are there ultimate last step pads.Which lake country for finishing? Ever tried their Gold Jewelling?
Well I was trying to see if you've used their CCS Gold Jeweling pad, it's apparently even softer than their Red pad and good for both Jeweling polish as well as Wax or Sealant. Thanks though.Both constant pressure and hydro tech, the finishing pad's I use are there ultimate last step pads.
Mabey same pad's bud, here's the one's I use-Well I was trying to see if you've used their CCS Gold Jeweling pad, it's apparently even softer than their Red pad and good for both Jeweling polish as well as Wax or Sealant. Thanks though.
Thanks,Mabey same pad's bud, here's the one's I use-
http://www.polishedbliss.co.uk/acatalog/lake-country-ultimate-last-step-pads.html
