1 - 5 of 5 Posts
Hello,
I've done my car using P1&P2.
Using IPA 1:3 to clean panel, it creates some holograms...
Using the cleaner Dodo lime lite on a RED LC Pad, the surface is perfect...
My question is : can I apply C1 directly on the Dodo cleaner ?
Thx
No.....
You need another IPA wipe down prior to C1 application to remove any of the oils/fillers left by the Dodo Lime Prime...this ensures a perfectly clean and clear surface for the C1 to adhere to AFAIK
Thx for answering.
I will try the GTechniq wipe panel then, hoping no hologram will be created using it with a soft MF.
EDIT : IPA create marring (not hologram in fact), i hope PW will not... :)
Panel wipe and a soft MF cloth won't cause marring but doesn't lime prime lite contain fillers? If so, utterly pointless using it before C1 and EXO.
1 - 5 of 5 Posts
