1 - 6 of 6 Posts
Obsession Wax Rep
I have a das pro and was wondering if you guys can problem solve for me.
It seems to slow down from time to to like its not getting enough power then it returnsvto normal.
Could it be a chord issue or the bushes.
Was not sure which section to post and apologise if its wrong.
Any help will be great.
Will
I did not change it just trimmed off the broken bits.
The cables gives way just after the rubber sleeve as it comes out of the bottom.
Open up your DA and it it pretty self explanatory. About 4 screws to undo to get the cable out. Cut off about 2 inches of cable sleeve and you should see where the wires are broken.
Cut below the break and refit.
Half hour job tops.
1 - 6 of 6 Posts
