Hi, I've been reading lots of posts and have a good idea of what I want to do to fix my Transit Custom sill rust but I am stuck on one part.
The rust is penetrating up behind the stone chip and paint on the outward facing surfaces and surely up between the steel sheet sections forming the bottom of the sill seam.
How can I deal with the rust between the steel layers? Some sort of acid to strip the inner paint/rust layers so I can feed Hydrate 80 from inside the sill cavity? I can't fit much (if anything), tool-wise, between the layers to remove the paint/rust.
I can't imagine Dynax-S50 would penetrate down through the cavity and through the paint "curtain" to halt the rust sandwiched between the bottom sill seam.
It's a real head scratcher to me...
Thanks for reading.
Thanks for reading.
