Juddering wiper blades
1 reading
12K views 27 replies 19 participants last post by  donnyboy
So I bought a car a month ago and my wiper blades are juddering, at first only on downstroke, since I putting them on fastest speed (where they don't judder ironically) they now judder on both up/down on all speeds except fastest.
Car is a 2017 Audi S3 3 door 8V model.
It seems to have been detailed in the past, it collects wax water droplets and the bodywork looks good when this occurs (beading). But it seems someone waxed the windscreen with some wax that is IMPOSSIBLE to come off.
I have tried the following
- new wiper blades, from Audi, twice.
- autoglym glass cleaner + polish
- T-cut
- jet wash
- vinegar and newspaper, 3x, over a period of 3 weeks
None of these has managed to get whatever is on the windscreen to come off.
It is so bad that if it rains I can't use the car. Not only because of the juddering but because whatever is on the screen collects all the rain drops and then you can't see out of the screen.
At 70mph all the rain runs off the top of the screen like RainX but I've never encountered RainX that behaves like this or doesn't come off with vinegar applied.
I don't really want to have to take it to a detailer who will charge me an arm and a leg to remove it? And a new screen I think is out of the picture as it has auto wipers etc.
It has audi warranty but I'm not sure if this kind of thing is a warranty issue?
Any ideas please? I don't trust myself with a machine polisher / wire wall pad etc.
#10 ·
Felt pads is what you use for polishing glass, some felt pads and abrasive glass polish should remove it.
Failing that or for a quick fix there's 2in1 glass cleaners around that clean the glass and leave behind a temporary coating, the temporary coating should more the screen slick enough so the wipers won't judder.
#16 ·
So wet microfibre, + barkeepers friend powder...did this today.
It's much better, just noisy wipers now, the passenger one seems to "jump" when it gets almost to it's bottom resting position and can't figure out why. Noticed a slight bit of juddering from the driver one but only when the windscreen was practically dry. I've not sealed it or polished it, just used the barkeepers a few times. I can now see the lines where the wipers stop etc which I could not see before.
I will give it a go when it rains, if it works then i need to look at replacing the wipers I think, they are incredibly noisy...squealing (and squealing when cleaning them with a cloth) for genuine audi ones that are only a week old.
People rave about PIAA Si-Tech ones on these cars so...
#19 ·
give it another couple of passes with the Bar Keepers and it should stop the juddering, it sounds like you're almost there :thumb:
#24 ·
Mine were driving me crazy! I had glass sealant on but my wipers were driving me crazy juddering, I just used a cutting compound and a das6 to machine polish it off, was off in 2 mins, coating totally dead. what a relief! So I stupidly used a snow foaming sio2 coating all over the car and the wiper judder was back, machined it again with menzerna cutting compound and it was dead again. will stick to hand waxing from now on!.
#28 ·
I had issues with smearing and juddering. Tried a few things. Strong cleaners, magic erasers. new blades etc.
This is what cleaned it - https://www.ebay.co.uk/itm/Soft99-G...-Glass-Compound-Roll-On-Glass-Screen-Cleaner-Polish-MADE-IN-JAPAN-/402309524902
Then the glass sealant - https://www.amazon.co.uk/SOFT99-410...co-Roll-Large-Glass-Cleaner/dp/B0035ZJYB8/ref=pd_lpo_2?pd_rd_i=B0035ZJYB8&psc=1
If I ever get issues with glass I go straight to the cleaner.
Set of both - https://www.amazon.co.uk/SOFT99-Glaco-Windscreen-Compound-Cleaner/dp/B074KBQP5C
