Hey boys and girls, the Junkman here with another video series! This time we introduce another way to maximize the power of your PC buy using a technique that makes up for lower OPM's when compared to the RPM's of a rotary polisher. I also use this technique to test the hardness (or softness) of a car's clear coat. Lastly, this method will allow you to keep from wasting polish as your pads fill up. You can actually stretch how far your product will go using this technique.
This technique was originally conceived to be used with harder type polishes. It enables the polish to be fully broken down and maximizes it's use. What you are going to see is that it can also be used with a polish like Adam's Swirl & Haze Remover, Meguiar's M105 or Zaino's PC Fusion. Furthermore, it allows you to use less product, while stretching the mileage of each application. It also saves your pads from getting caked up with product which is a major waste of money and resources.
You won't use this technique on the entire car or use it all the time. One of the reasons that you will implement it when using a liquid type polish is when your pads begin to fill up with product. It will be used until the pad is no longer caked with polish, at which time you should go back to the regular process of using 9-14 pounds of pressure on a setting of 5 (with the PC-7424XP)
Enough talk, let's get to the videos!
Here are some pictures from the experience:
That's all folks!
The Junkman
The Videos
That's all folks!
The Junkman
