1 - 4 of 4 Posts
I have been looking at a way to snow foam without a pressure washer. After looking through some threads it seems the mesto hand foamer gives good results but requires constant pumping as it loses the pressure.
Now the eazi bleed brake kits use the pressure in a spare tyre to power the kit. This got me thinking about modding a mesto to use the same idea and use tyre pressure to give a better usage time.
Any ideas or has anybody tried this?
Discussion Starter · #3 ·
Well the eazi bleed gets you to reduce pressure first. I would need to work out what rhe mestro pressurised to and then just use a spare set at that pressure
1 - 4 of 4 Posts
