1 - 13 of 13 Posts
After doing a dent pull, the tabs have hotgluegun residue stuck to them...
I have tried leaving them in 99% alcohol overnight but I still can't pry the glue off... making them somewhat unusable
See pic
Toy Pink Magenta Sports equipment Circle
Pink Petal Magenta Material property Tableware
It should just peel off with a spray of alcohol.
  • Like
Reactions: ridders66
The usual method is to use acetone; this is what PDR professionals will use, and if you have bought a DIY PDR kit, it should have a small bottle of acetone included.
If you don't have any acetone readily to hand, acetone is also the major constituent of nail varnish remover.
Discussion Starter · #9 ·
Thanks for the replies guys, the hot water in combination with alcohol worked but was alot of effort
I think its because my tabs have an ingress pattern the glue gets stuck
1 - 13 of 13 Posts
