1 - 11 of 11 Posts
Hey guys,
I have some problems with rain X. I applied it to both windscreen and side windows. No problem on the side windows, but on the windscreen, I might have applied to much... There seems to be still a layer on it, and when the screen fogs up or is wet, you can see a layer and even the circular motions I made when applying it.
Now, no matter what I do, I can't seem to buff it off, and the rain X isn't doing it's work... the water just stays on it, not running off.
any help is very much appriciated :D
+1 reapply let it dry, then buff with a clean mircofibre/paper towel should sort it out, clean wiper blades as well since it will have contaminated them as well and that will leave streaks across your screen.
Been there done that myself :mad:
Meths (the purple stuff) used with care not to get on the paint or plastics should get rid after a good scrub followed by a polish. You will have streaks from the wipers as they have Rain X on them and no amount of cleaning the rubbers will sort so buy new ones once the screens been sorted.
Start again chap. Meths, IPA and Eraser all work as it's alcohol based (i expect cheap vodka would probably work too)
Give it a clay, polish and re-apply or get something else on it. Did you use water when bugging off?
Discussion Starter · #8 ·
I will get some new wipers on my next service I guess, so thats not a prop.
I'll just use the wife's cheap vodka then :lol: I'll have a go with Eraser first...
I did use water to buff it off... Guess that was a bad idea, but it took veeeery long to dry to, probably with the weather these days?
Do you live near the coast? I had problems with Rain-X and it turns out living close to the North Sea salt heavy air is bad news and fogging was a real problem. Cleaned it off and Aquapel was better but not 100%.
New car and ADS Glass solves the issues.
I guess you get what you pay for....
No, not that close to the sea...
I was going to get some Wolf's glass coating, but heard it was going to freeze, so went to get some Rain X... pure waste of money
The Rain-X needs to be buffed off with water or it will leave a greasy residue on the screen. I have used it for 10+ years on many cars and have found that spraying the screen with water and buffing with kitchen roll works best.
It's great stuff and I even went back to it after trying the G-Technic stuff - personal preference I suppose.
Good luck,
Cooks
Discussion Starter · #10 ·
update on the story. I tried cleaning the windscreen with Eraser and IPA, but that didn't work. so I took out the glass polish and I think that did the trick. Re-applied and buffed of with some water. Hope that wil have done the trick. I'll keep you updated
Nanolex is my preference, but Rain X is pretty good. I usually dampen a microfibre then spray it on that first, then apply in a crosshatch fashion and buff off with a dry MF. Always worked perfectly for me personally
1 - 11 of 11 Posts
