Please post in our Community Feedback thread for help with the new forum software! If you are having trouble logging in, please Contact Us for assistance.
Recommendations?Praefulgeo wouldn't work as a drying aid, even diluted and will smear and haze, completely different breed of sealant is Praefulgeo
Russell may advise whether HDD have sent you the latest mix, or an earlier batch. What you are describing to me would sound like the early batch and I found applying a little more product into the applicator and spreading before wiping off with a second towel was the way to go. Any light residue that has already flashed and doesn't wipe off immediately can be re-activated with a spritz of water or wetting via a damp cloth. I found that the earlier batch needed to be shaken regularly and had very little tolerance to be used in the wind, higher temps or in direct sun, where the new batch is a LOT more forgiving.I’m applying it now in shade, seems ok, still working out how best to apply it. I’m doing about 6 or 7 small or half sprays into a MF and doing it on say a 3x3 section at a time, working it in well and buffing off. Roughly 30 seconds till buff off by the time I’ve spread it round. Buffing it off seems to leave a slight residue, would I be best with a damp cloth and then buff off to help?
Done 70% of a 1 Series and barely used any really
Just one question ............. why?Still using & triailling in various applications.
SiRamik topped with PA
PA topped with SiRamik
Agreed, it's the best LSP for durability, but lacks the PA look for me.Just one question ............. why?
When you top Lustrous you will get the hydrophobics, looks and performance of that product, and loose the attributes of Lustrous.
When you apply Lustrous on top of another product, rather than bare and cleansed paint, you will (probably) compromise the durability of Lustrous.
Alan W
Thanks Russ 👍You will only do 2 things if you top another product, that is weaken lustrous plus and potentially strip what's underneath anyway, unless it's a full blown coating that withstands high solvent content.
I’ve topped my freshly applied (2 weeks) Exo V4 with Lustrous (been paint corrected). Don’t rate Exo that much and had some spare to use, and then found LustrousYou will only do 2 things if you top another product, that is weaken lustrous plus and potentially strip what's underneath anyway, unless it's a full blown coating that withstands high solvent content.
You could try the full blown lustrous coating itself, or the tried, tested and wetter than an otters pocket SC15 underneath Lustrous Plus, every SiRamik product is developed to perform, graphene is a new breed so had to be durability first, which is undeniably outstanding, thing is because it's not rGO (reduced graphene oxide) like 99% of other spray sealants or QD's it doesn't incorporate anything that could affect its durability, even the full blown coatings of certain others contain no true graphene.Thanks Russ 👍
I guessed as much.
Do you happen to do/ looking into a higher gloss version of SiRamik?
That is my only gripe with the product, as PA still edges it for looks and more suited to a garage queen than a daily driver.
