VW Bora/Golf MkIV PD130 Clutch
7.8K views 9 replies 6 participants last post by  weemax
That is a VERY cheap price and everything you need is in that kit. Only other thing to look out for when it is apart is the rear main oil seal leaking. These are about ÂŁ50.
You really don't want a SMF conversion on the TDi, it is horrendous!
Also unless you are planning on hybrid turbo there is no need to get an up-rated clutch plate and cover. Plus it is ALOT more expensive. ÂŁ536 + vat just for the plate and cover, you then need the flywheel and release bearing.
