121 - 140 of 238 Posts
Gentlemen,
I just received a bottle of SRP and was planning to use Duragloss 105 Paint Sealant over it. However, DG 105 has mild cleaning properties. Will this remove the fillers in SRP?
In my opinion Duragloss 105 is more of an all in one type product, so yes it will remove the SRP
So how about DG 105 first and then SRP?
Else, I have some Dodo Waxes and Optimum Car Wax lying around, can either of these on SRP? I am guessing SRP plus Wax would be as durable as SRP plus EGP?
You can top SRP with any wax or sealant...
SRP + EGP is a good combination but I would still top with a wax for the warm gloss.
I only have DG 105 for a sealant and Dodo / OCW for waxes.
It's been advised in this thread not to use DG105 so I am considering going straight after SRP to Dodo.
Is a sealant necessary? If yes, isn't EGP a better choice as it will probably have the same fillers as in SRP? A sealant from another brand may strip some of the fillers in SRP. Am just trying to understand really.
EGP has no fillers that I could detect over what any other sealant has.
You may be getting confused between a Glaze which has fillers and a light carnuba base in there as well.
I think you are worrying about it a little too much :) Just top with whatever your LSP of choice is... Bearing in mind than a AIO product (products similar to SRP in their own right) . Any sealant or wax will be fine to use.
How about one OCD talking to another OCD and trying to figure out if the fillers and oils in SRP will allow any sealant to bond?
Any sealant that is a pure sealant (as in not an AIO) such as Auto Finesse Tough Coat, Autoglym EGP, anything like Collinite, CG Jetseal 109, etc etc, all are perfectly fine.
Only thing I would not do is put SRP under things like a ceramic coat such as C1 crystal laquer or Ceramishield.
Thanks a lot. I will avoid DG 105 as there is a lot of debate about whether it is an AIO or a true sealant or a mild AIO with a sealant etc.
SRP plus Dodo Juice Blue Velvet Wax it is then.
Is SRP a true AIO, meaning does it have any sealant properties? If I don't top it up with a Sealant or a Wax, how long can it protect the paint for? I was thinking if it could hold the fort for a month, I could use it once a month. If not, can a simple spray wax like Optimum Car Wax or Meg's UQW help SRP protect the paint for a few months?
SRP is an AIO and a very good one at that. It will leave a sealant layer behind that will protect the paint. The new version is a great product that should last a few months just on it's own. You are better topping it with something like AG EGP for a great look and maximum protection. EGP is about ten quid for a bottle. For many years I only used SRP, discovered this site and have been skint since. SRP and EGP are a great combination
I have found it lasts weeks, tops, without being topped by a wax or sealant. Even with the new version.
I spoke to a professional detailer about using DG 105 after allowing SR to cure overnight and he said despite the mild cleaning properties of DG 105, it should be fine. He said SRP is not easy to remove and may need to be clayed and polished to remove. His recommendation is SRP>DG 105>DODO Juice Blue Velvet Wax>OCW. Seems excessive to me, what do you think?
