Das 6 pro vs Das 6 pro plus
14K views 12 replies 6 participants last post by  Ashburner
I have a Das 6 pro currently but want to upgrade as it seems to take a while to correct hard German clear coats.
I have read some reviews on the pro plus but have a few questions of my own that I was hoping someone could answer
I have Menz2200 and MF cutting pad which I'm using to correct the swirls on a BMW just now, it's doing an ok job but taking a good number of sets to correct,also it is not correcting some RDS the car has.
If I were to use the pro plus, would it cut more, Ie take out the RDS using the same m2200 and pad combo? Or would I still need to move onto a more aggressive compound? Also would it need less sets to remove the swirls?
Next thing is I realise the pro plus doesn't take small backing plates, I have a 3" plate for my pro just now, what do you all do for the small areas when you only have the pro plus? As I was going to sell the pro to help fund the pro plus.
Thanks guys
#2 ·
All things being equal, the Plus should cut faster because at a given speed the pad is covering more distance than it would be on the normal Pro.
From what I've read on here I think the Pro Plus can take small backing plates, it's just that the larger orbit on such a relatively small pad can make it difficult to use due to increased vibration etc.
What size pad are you using on the current machine? It's worth remembering that smaller pads cut harder on a DA, so if you have localised defect removal to do you might gain extra cut by using a small MF pad?
#13 ·
Seeing as you mentioned the paint being tough, I'd step up the compounds to something like Menz FG400, and an Orange Hex Pad/Green or Yellow Rupes pad, and use that with your DAS6 Pro.
As mentioned in here, the Pro+ seems smoother and with a bigger throw which means a quicker time to complete the car, but not quicker cut times, that comes from the Pad/Polish combo.
