Pipercross performance air filter
15K views 22 replies 14 participants last post by  millns84
Thinking of buying a piper cross performance air filter for the ST220, seen them on eBay for £35, anyone got any experiance of these, are they worth it and are the claims of more performance etc true?
Many thanks for any input :thumb:
#4 ·
In general no they are a waste of time performance wise, they often make performance worse. they will make a noise though so depends what your after
the key is getting as much cold air as possible, removing an air box for an open end cone filter just increases hot air intake unless there is a heat shield from the engine
A good mod is too create another cold air feed to the air box and de restrict if applicable
I will say, this doesn't always apply, but 9/10 this is the case. Be the performance gain/loss in either direction is minimal. So if you want the noise go for it, you won't loose noticeable performance but it sounds nice
have a look at this, different car obviously but gives a comprehensive write up with dynos of different induction set ups on the same car
http://www.clubgti.com/showthread.p...37-Toyotec-s-how-to-make-your-MK3-16v-breathe-on-a-budget-Part-2-added-14-12-09
Concludes that out of all possible set up, some of which are very expensive, the best is the standard air box, drilled on the opposite side to the engine and the internal valve removed
Cost £0, and sounds awesome, I know cus I've done it
#11 ·
I had a pipercross on my Octy vRS for a few years and it was fine (reason I got it was that VW Racing used rebadged pipercross filters in their cars at the time). The thing with filters is that the BHP gains are minimal and unlikely to be noticeable by themselves (a few horses probably, although with other mods like re-maps etc things start to accumulate), but they can in some cases slightly increase induction sound (which is always nice).
I know I will get the K&N devotees on my back for this, but I got the non-oiled piper at the time (and I have a non-oiled cosworth filter now in my GT86) and avoided K&N because if you overdo the the oil replacement when cleaning it there are stories about how it can seriously screw your MAF if it gets gunged, and that's potentially a very expensive fix. Yes, I know people will say K&N (and other oiled filters) have sold so many that they must be safe, but I just take the view that a non-oiled filter (which of course the OEM paper ones are) is the safest option when there is plenty of non-oiled panel filter choices out there.
Of course the other issue you need to consider is if you are not going to use oiled filters, and you want something with more airflow than OEM paper ones, you need to be careful that they are not too lax in the filtration department - which is actually why I went cosworth this time as the material they use seems to be a lot better than the pipercross foam layers.
#16 ·
Is this for a cone or panel filter?
On a V6 you will get terrible heat soak with a cone, sit in traffic in summer for a good few mins & the car will run lumpy and sluggish. (Unless you fab up a heat shield)
I had one on a Vectra GSi and it was too loud once the induction roar novelty had worn off too.
A panel filter with give a teeny tiny bit of extra throatyness but will run loads better.
So here's the trick (& will probably get plenty of grief for suggesting it)
Put a panel filter in and then hole saw a few times the underside of the airbox for a bit of roar without going too far.
I did this to my 330ci and it sounded immense and ran perfect with zero issues for 40k miles. :)
I also have a piper-x filter in my current car, but with it being a diesel I didn't want it any louder lol! But is fine & wouldn't hesitate to put one in my next car either bud.
#20 ·
When i had my Evo 8 9 years ago we did a dyno test with just a panel filter, 4bhp increase was noted without doing anything else, after that things got serious mod wise,but was the best 4 years spent driving a car!:car:
no harm in fitting one IMO though id recommend cleaning them every 3 months whatever manufactuer you choose K&N pipercrosss etc
#21 ·
I have a pipercross replacement in my TXS. noticed absolutely nothing. Well mpg gone up slightly. I only got it because it was a tenner and I don't have to buy a new filter each time so two filters will pay for itself. Best filters are the manufacturer. 99.99% efficient in tests. There was a test a while ago in a fast Ford magazine. they let in next to no dirt. When you go performance you have bigger holes for air to flow through therefore letting in bigger particles. I have a tdci and noise has improved slightly but I didn't fancy listening to a tractor so a replacement rather than an open filter was fit for needs.
Ryan
