Skoda Octavia VRS Mk2 opinions please !!
5.7K views 20 replies 9 participants last post by  Tricky Red
Hi all.
We are looking at going back to an estate car from our Smax and have found a nice Skoda Octavia VRS estate for sale at a dealers in Edinburgh.
Its a 2010 facelift 2.0 TSI petrol version.
Is there anything specific I should be looking out for??
Any owners of a vrs that can give me some honest opinions on what they are like to live with??
Whats the Mpg like?
We did initally look at an octavia around 2.5 years ago before we settled on a mazda 6 sport estate but fancy an Octavia this time.
Steve
#4 ·
I've had mine 4 years, 30mpg daily and up to 43mpg on a good run.
Have a read about chain tensioners on the 2.0 TSI engine.
Other than that they are good cars without major issues.
Can be noisy (road noise) down to tyres and alignment, same as all the VAG cars on this platform! They call it sawtoothing of the rear tyres.
Great cars for the money, basically its a mk5/6 Golf GTi underneath with more interior space, so a tried and tested car.
The TSi engine in the Facelift is very very tuneable too if that's what you like. A stage 1 map will produce about 255-260bhp and won't increase fuel consumption by any great degree.
Struggling to think of a replacement for mine after 4 years and before I've always changed after 2 years.
#5 ·
Cambelt and water pump change, if it the tfsi check the fuel cam follower, if it's the tsi then as mentioned above be aware of the tensioner issue. I ran a cupra tfsi for 4 years and 55k and nothing went wrong with it was a great car, the engine was good but needs the remap and exhaust although the clutch doesn't like it.
#7 ·
Does it have a sunroof ?. Reason I ask is our estate was prone to the drain holes from sunroof blocking and the carpets used to get wet, but never saw a single drip or damp patch around roof area. Was a simple enough fix just cleaned the drain holes out with some nylon strimmer cord.
That said we also had a leak in boot caused by a rear light seal that failed. Other wise it was a spot on motor.
#11 ·
Its probably one of those internet things but some things are genuine issues (Mini with coke and tensioner issues, HPFP etc)
I would actually look for an L&K Estate if you wanted the Octavia, although my money would go on the Superb with 1.8 TSI Elegance, Skoda are doing 0% on some models so it might be cheaper to go down the PCP route.
#19 ·
Thanks for all the replies so far..
Before the Smax we had a Mazda 6 sport estate that we really liked but it was let down by very poor paintwork.
When looking at the Mazda we also considered the Octavia VRS but couldnt find one in our budget with the spec we wanted.
Need an estate car for the springer and kids junk that goes with us every where.
The thing with the Smax is that although its a nice car and pleasant enough to drive, 95 % of the time its to big for us, I guess we didnt realize until we bought it.
As our kids are now starting to get to the age and height that they dont need booster seats Im sure we could get away with an estate car with a roof box.
Also the Smax does an average of around 29mpg and isnt that quick to be honest and it never makes me want to just go out for a spin in it!
#20 ·
I doubt you will get many more miles to the gallon out of the vrs, my cupra averaged between 26 and 28 mpg on a mixed route of 15 miles each way. My mini clubman now averages 38 mpg. The cupra on a run would hit around 33/34, mini averages around 46mpg. Have a look at the fuel figures on honest john but as a guess I would say you would get around 32/3 out of the newer tsi.
The superb is massive inside but it's the boot space, even if you went for the saloon you can turn it into a hatch.
#21 ·
Vrs is brilliant. I did 50k in mine without many issues other than tyres.
Not many issues at all. Wheel alignment needs to be set up properly as factory bods are a bit lazy with getting it right. Petrol will give you upper 30s on motorway if you're steady.
Interior is nice, gearbox lovely on mine.
If you want a remap, make sure that the torque curve is smooth otherwise you will hurt the clutch. Basically use the revs too rather than high gears from low speeds as this will eat a clutch with a remap.
I was on same clutch at 90,000 and there was loads left.
I sold mine a couple of years back. I'll dig out my link
http://www.detailingworld.co.uk/forum/showthread.php?t=281786
