What is good chemical to remove hard water/acid rain deposit stains on the windows?
21K views 29 replies 26 participants last post by  Swad
Hi guyz.
I have this hard water stains/ acid rain deposits deposited on the windows of my car which has become a headache to me now. I personally am an AutoGLYM enthusiast so I purchased the AutoGLYM Car Glass Polish and tried to remove the stains but it didn't work at all. Can anyone suggest me a good chemical to remove these stains off my windows.
#12 ·
You need an acidic product, any recommendations to the contrary are wrong. Don't panic too much about the paint, this is another example of DW misinformation. There are any number of products, routinely used by those on DW, which are much more hazardous to your paint than a bit of vinegar or citric acid.
Polishing - yeah, you could use an abrasive like ceriglass, but it is aggressive and unnecessary when you can get the job done with a mild chemical cleaner.
#16 ·
0000 wire wool works brilliant but use with caution if a first timer e.g if the rubber seals are not over lapping you don't want to hit the painted panel!! I use a liquid window cleaner and wirewool or during the washing process. I remember a friend of mine phoning after he had used wirewool and autosmart r6 I think he cried a bit that day!!!!
#24 ·
Wouldn't have thought so - it's the main ingredient in cheapo window cleaners, so should be fine. If you're worried, just try it on a small area first, see what happens :thumb:
It should react with the scale from the watermarks anyway, so that will neutralise it (or you use a lot of vinegar, reduce the overall acidity).
#29 ·
Powder is more concentrated and has more bite, i think.
Don't try to put the powder onto the glass as it will go everywhere, but try this method, which works well for me :
Lift the windscreen wipers and have a hosepipe ready.
Get a cheap yellow car sponge - get it nice and damp - then sprinkle a little of the powder onto the sponge and let it get damp for a few seconds.
Then you can move it over the car onto the windscreen area and carefully turn it over and work the powder around the glass. Just go slow and carefully work the whole windscreen with a little pressure.
When you are done, turn the sponge back over and lift it away from the car.
Then use a gentle hosepipe mist or stream to wash the BKF down the windscreen and into the rain channels and away. Use plenty of water to rinse out the rain channels afterwards to make sure it is all flushed off the car.
Worth the effort as it is absolutely epic at getting stubborn stains off glass.
