Wool Pad recommendations
1.8K views 3 replies 3 participants last post by  Sawel
Folks, I am looking to buy some wool pads and looking for some recommendations?
I will be using them on a rotary and flex 340. Many thanks
#4 ·
For the Duetto - I recommend a thinner version of the Lake Country Purple foamed wool pad. The thinner version was designed specifically for dual action polishers. http://www.cleanyourcar.co.uk/machi...-country-constant-pressure-pads/lake-country-5-5-inch-foamed-wool/prod_632.html
The good folk over on Autopia did a test using a range of manufacturers pads on a dual action polisher and concluded the thin wool pad cut more than the Meguiar's microfibre cutting discs. https://www.autopia.org/forums/the-...the-detail-institute-presented-by-autopia-carcare-com/43194-da-cutting-pad.html
I've used the thin foamed wool pads on a Das 6 PRO and was very impressed with the level of cut.
The Scholl Topwool pad wouldn't work properly on the Duetto as the nap is too long and is best suited to forced-drive polishers.
#3 ·
